Answering my own question, yes, I needed to uninstall and reinstall. This has me past the Kmotion version issue.
MM however does not seem to open on my machine. I see the process in task manager, but so far, after a 10 minute or so wait, the GUI still has not appeared.
Grace
PS-- I
--- In DynoMotion@yahoogroups.com, "gracemckay" <grace@...> wrote:
> So, to clarify, MM is supposed to work with 428, and you have updated the file at the link below to work correctly with 428. Is this correct?
> If so, do I install the new MM version over the previous AM version, or should I uninstall the AM version and reinstall the new one?
> Grace
> > I meant to say 4.28x was an "out of band"
> > Where is the edit post feature around here?!!?
> > -Brad
> > > You need 4.28 to run MM.
> > > 4.28 was an "out of band" release that had most of what was needed but required manually copying some projects and patches to the KMotion install path.
> > > DynoMotion has simplified this and 4.28 should work with Machine Manager right out of the box(though there are many other updates in this version that are not MM related).
> > > I just updated the install package here and on SourceForge and the previous OpenGL compatability requirements were resolved.
> > > As far as beta issues and gotchas... I'm hoping they are minimal but also expecting people to let me know about them so I can resolve them as quickly as possible.
> > > Regards,
> > > Brad Murry
> > > --- In DynoMotion@yahoogroups.com, "gracemckay" <grace@> wrote:
> > > > Within the last hour... I have just installed Kmotion 4.28. I then downloaded and installed the latest version of MachineManager from this link http://sourceforge.net/projects/cnctw/files/latest/download?source=files
> > > > Machine Manager is reporting it needs 428x to run. I see from the thread on cnczone that Brad has first stated that it needs 428x, but later in the thread that it needs 428. So the questions are-- which version of Kmotion, and is there any danger to installing 428x, any beta problems I will encounter, and other gotchas I should be aware of?
> > > > What is the best way to handle this?
